Driver's side door sag. New hinges needed?
Old Apr 26, 2010 | 05:00 PM
BADST GS-R's Avatar
BADST GS-R
Default Driver's side door sag. New hinges needed?
My driver's side door on my 2001 Acura Integra GS-R sags a little bit once I open the door and because of the sagging, I have to slam it a little more to get it to close. What have you guys done to repair this problem? New hinges? Bushings? Thanks in advance.
Old Apr 28, 2010 | 11:20 AM
BADST GS-R's Avatar
BADST GS-R
I guess that I must be the only one with a sagging door on an Integra. :chuckles:
Old Apr 28, 2010 | 06:39 PM
Spec R's Avatar
Spec R
if the hinges are tight and dont have slack, it could be a slight chassis issue.
integra's are getting old so problems like this arent that rare. has the car been in an accident?
DB Squad
Integra Forum Moderator
Old Apr 28, 2010 | 07:47 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
I just saw on Honda-tech that this was covered. They were replacing the hing pin I believe. Although I really like Honda-Acura.net the tech sections have almost died.
Old Apr 29, 2010 | 05:29 AM
Lynxs1981's Avatar
Lynxs1981
Yes, it's usually a hinge pin/bushing combo issue.
Old Apr 29, 2010 | 02:38 PM
BADST GS-R's Avatar
BADST GS-R
Do you have a link?
Old Apr 29, 2010 | 02:54 PM
BADST GS-R's Avatar
BADST GS-R
Any idea on part numbers?
Old Apr 30, 2010 | 05:41 AM
Lynxs1981's Avatar
Lynxs1981
67410-SH3-K02ZZ Top hinge
67450-SH3-K02ZZ Bottom Hinge
They're about $35 from a dealer
Old May 1, 2010 | 08:21 AM
BADST GS-R's Avatar
BADST GS-R
Do you think that a new pin would be required? Thanks.
Old May 1, 2010 | 04:57 PM
Lynxs1981's Avatar
Lynxs1981
They usually come as an assembly. It is the bushing that fails most often, so I would start with just the bushing if you can find it. Depending on how long it has been this way, then a new pin might be needed; but you won't know for sure until the old one is removed.
