b16 in 94 civic
Old Jun 26, 2002 | 01:52 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
Default b16 in 94 civic
Will the existing wire from the ecu to the engine compartment fit the wires from the motor of a b16 out of an Si? Also would the axles and linkages line up correctly too? thanks
Old Jun 26, 2002 | 09:02 PM
gritsak's Avatar
gritsak
Default Re: b16 in 94 civic
the wiring will work, i think the only thing you might have to do as ad one wire for the knock sensor.
im not too sure about the axles and linkage, when i did my swap it already came with the linkage and axles from the b16 so i just used them.
Old Jun 28, 2002 | 11:15 AM
AP2's Avatar
AP2
Moderator Alumni
The '94 Si axles will not work on your b-series motor. The spline is different.
Old Jun 29, 2002 | 04:49 PM
taylormadem5's Avatar
taylormadem5
you need this: ECU, axles, shift linkage from a Del Sol or the SI these should come with the engine swap , and engine mounts from either a Del sol, SI, or an integra ...the wires should match up..but you may need to swap the harness that is in the engine compartment seeing how your going from SOHC to DOHC and there are some extra sensors that are not on your stock SOHC harness..my best friend just sawpped a B16A3 in his civic and thats what he had to add and sawp on his engine
Old Jul 1, 2002 | 12:27 PM
likaciv's Avatar
likaciv
we are swaping a harness from a gsr to the motor, therefore we are able to use the stock chasis harness, i would be interested in knowing what sensors i am going to have to wire in.
JDMLyfeStyle
May 31, 2005 09:24 AM
dirtydozen
92+ Civic/EL & Del Sol
2
Aug 29, 2004 12:58 PM
vtec28412
Showroom
Mar 10, 2004 02:34 PM
untensadude
Nov 14, 2003 03:51 PM
19.3secS2K
6
May 28, 2003 09:00 PM
