Engine Sounds Louder
Old Mar 6, 2010 | 03:14 PM
Fess's Avatar
Fess
New York Trini
Default Engine Sounds Louder
2000 integra
30,307 miles (hardly driven)
So I have moved to L.A. (work related) and shipped my Integra from FL....since August 09.
Just took it in for 30,000 schedule and there was squeaking coming form the front passanger wheel when driving (front rotors needed resurfacing and brake pads replaced).
.......my engine is noticiably louder after a few days of driving.
Why????
Any input on this?
Thanks,
Fess
Old Mar 7, 2010 | 04:11 PM
Line7's Avatar
Line7
Platinum Member
Probably got an exhaust leak.
Old Mar 7, 2010 | 07:51 PM
Fess's Avatar
Fess
New York Trini
Line,
Yeah, think that might be it....
How troublesome is this?
Expensive to fix?
Thanks,
Fess
Old Mar 7, 2010 | 08:21 PM
Spec R's Avatar
Spec R
please check your oil or get an oil change.
i fear that the long period of time it spent sitting may have caused the oil to thicken and cause damage internally. but thats worse case scenario.
DB Squad
Integra Forum Moderator
Old Mar 8, 2010 | 11:30 AM
Fess's Avatar
Fess
New York Trini
Spec,
The reciept print out from my last vist said "exh leak". But I didn't know if it caused any issues.
Anyway, amazing work on that burgandy teg restore....
same area, hollywood hills..
peace
Old Mar 8, 2010 | 11:54 AM
Line7's Avatar
Line7
Platinum Member
Originally Posted by Fess
Line,
Expensive to fix?
Thanks,
Fess
It all depends. maybe a gasket that needs to be replaced, maybe a broken hanger, maybe the pipes are just rusted through and need to be replaced.
If you dont mind getting dirty, get underneath there, or better yet, get it on a lift, and run your hand close to the exhaust pipes and you should find the leak.
Old Mar 8, 2010 | 12:50 PM
Spec R's Avatar
Spec R
Spec,
peace
thanks!!
yeah exhaust leaks are easy fixes. most random exhaust shops will charge u $50 to fix it.
DB Squad
Old Mar 13, 2010 | 09:22 AM
Fess's Avatar
Fess
New York Trini
turns out to be a crack in the resonator.
taking it to Midus for welding tomorrow
peace
