what's the deal with crank bearings???
Old Mar 24, 2003 | 02:39 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
Default what's the deal with crank bearings???
so i asked a mechanic about machining my GSR block and he mentioned something about how the crank bearings are a beeytch because it's a honda motor..
what does he mean by this???
i am in the process of rebuilding my block, so i need to find out any info about replacing bearings, seals, pumps, etc..anything helps..thanks!!:thumbup:
Old Mar 24, 2003 | 03:44 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Honda bearings come in a slew of sizes(denoted by color), so you have check the clearances with the existing bearings, and then either step up or step down on the bearing chart, depending on whether you want more or less oil clearance. Maybe that's what he's talking about.
Old Mar 26, 2003 | 02:32 PM
TheRooster's Avatar
TheRooster
Former Senior Member
I don't see how they're a biatch. You just match up the number on the rod to a number or letter on the crank and go to the chart. Then like inspyral said, step up or down a color depending on wear or preferred clearances. They're not anything really that different than regular bearings, except that it'll set you back 120 bucks for the crank and 80 for the rods compared to 80 bucks for both if you go with unmatched generics.
Old Mar 26, 2003 | 10:32 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Certain bearing colors can sometimes be on backorder,a dn that may hold you up. Or, maybe he's just lazy and doesn't like checking clearances :dunno:
