spOOn
Old Mar 12, 2003 | 02:49 PM
PearlBlueB16's Avatar
PearlBlueB16
Default spOOn
Does anyone have the spoon camsprockets? What do you guys think of them? Are all cam gears the same?
Old Mar 12, 2003 | 02:52 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
For the most part they all do the same thing.
Some people say that AEM gears slip, but will recommend any other brand.
Regardless the only way to make power with them is to tune them on a dyno, and with the stock cams you won't see much of a gain anyway.
Old Mar 12, 2003 | 02:55 PM
PearlBlueB16
I have the requsite I/H/E combo and am installing some type r camshafts so i wanted to throw on some gears with them. Are yu saying it wouldnt be beneficial to me to put the gears on without dyno tuning it?
Old Mar 12, 2003 | 03:51 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Well, the whole purpose of the cam gears is for dyno tuning. It will definitely be helpful if you have ITR cams.
Shingo
Old Mar 13, 2003 | 07:23 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The gears themselves don't make any power. They let you adjust the cam timing. Once you get them adjusted properly, they can make you more power.
Old Mar 13, 2003 | 10:36 AM
PearlBlueB16
I understand that, but is there any way to tune the gears without a dyno? is there a standard, or relative, setting with the I/H/E combo? thanks for the responses.
Old Mar 13, 2003 | 10:56 AM
DB7 2.0's Avatar
DB7 2.0
Banned
if you dont have access/time/money for a dyno at all, then go the drag strip. play with the gear settings little by little and run the car down the track after each adjustment.
Old Mar 13, 2003 | 03:12 PM
Snoopy's Avatar
Snoopy
been there done that
every engine is different thus everyone's settings wont be the same.
Old Mar 13, 2003 | 03:39 PM
PearlBlueB16
Where can I find camshaft break-in lube? Does the brand of lube differ in performance, as in, is one better than the other?
Old Mar 13, 2003 | 07:17 PM
qtiger's Avatar
qtiger
Just get a big tub of assembly lube, and don't be stingy with it.
