Misc. Honda/Acura: Badge Removal
Old Mar 11, 2003 | 06:24 AM
rlschi36's Avatar
rlschi36
Default Acura badge removal
Hey...whats the best way to remove my stock trunk badges?
I have a 92 GS-R with pitted "Acura" and "Integra"badges that I want to remove, and stick on a lone "Acura" red trunk emplemn in
the rear center. (Red emblemn on a white car.)
I was thinking of jimmying/prying them off with a screw driver, but I want to do as little damage to the paint as possible. Any suggestions?
Old Mar 12, 2003 | 05:03 PM
SpoonLegend's Avatar
SpoonLegend
use some thin rope. shimmy it in between the paint and the emblem, then work your way through. afterwards, use alittle gas to get the left over glue off the car. then wax and buff to a beautiful shine.
Old Mar 12, 2003 | 09:38 PM
jeff's Avatar
jeff
heat it up first, it is held on with glue, use a hairdryer then use floss to remove it by sliding it between the emblem and trunk, btw: there will be 2 holes behind the emblem.
Old Mar 13, 2003 | 05:20 AM
NVS's Avatar
NVS
That's Mr.NVS to you!
how would you go about patching those little holes?
Old Mar 13, 2003 | 05:55 AM
rlschi36's Avatar
rlschi36
Thanks for the input. Rope and heat are good ideas! I guess I'll have to fill the holes and paint 'em. Anyone interested in two silver (pitted) Acura Integra emblemns?
Old Mar 14, 2003 | 01:24 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
I am if it's cheap How much you askin?
Old Mar 17, 2003 | 07:56 AM
rlschi36's Avatar
rlschi36
Sorry, tore em up much pullin em off. They're junk.
Old Mar 20, 2003 | 04:32 PM
moyerek's Avatar
moyerek
The hard way is to sand the area down. Fill with bondo. Sand, Prime, Paint, Clear, work, work, work.
Easy way: Silicone caulk if you have a basic color (if you can find a silicone caulk to match your color)
or
latex caulk and then paint w/ nail polish(color matched to your car)
Prep the area first with some paint thinner and then apply caulk. Very easy.
You do want to fill the holes no matter what option you choose.
Old Mar 26, 2003 | 07:56 PM
BlueG2's Avatar
BlueG2
i rather leave the holes or even the emblems than try to patch the holes myself.. itll look harsh bunk...
Old Mar 28, 2003 | 08:21 AM
rlschi36's Avatar
rlschi36
What I did was the bondo method. I then sanded and painted over the holes with "Acura" touch up paint. You can't really see the work unless you are right up on it. Next time I'll do the "caulk" method. I thought about using my white window caulk, but I went with bondo. The caulk probably would have looked a little better. Why the heck did they put HOLES behind those pitted badges?
