i know its long but please tell me what u think it took me along time.....thanx
Old Mar 8, 2003 | 04:16 PM
blureintegragsr's Avatar
blureintegragsr
Default i know its long but please tell me what u think it took me along time.....thanx
Description Qty Price Cost
DC Sports Battery Tie Down 1994-2001 INTEGRA - BLUE $44.96 $44.96
DC Sports Billet Plug Wire Cover 1997-2001 INTEGRA TYPE R - BLUE $143.96 $143.96
DC Sports Billet BLUE OIL CAP $47.66 $47.66
Rev Hard 1.8 Integra Heavy Duty Clutch Set $368.00 $368.00
KAAZ Limited Slip Differential 94-01 Acura Integra GS-R(DOHC VTEC) (Front) (1.5 Way) $855.00 $855.00
DC Sports Short Shift Lever 1997-2001 INTEGRA $98.96 $98.96
Energy Suspension Manual Transmission Shifter Stabilizer Bushing Set 1990-2001 Acura Integra $16.19 $16.19
HKS Metal Head Gasket Stopper Type 0.5mm x 82.5 Acura Integra B17A, B18C1, B18C5 $196.86 $196.86
Golden Eagle Block-Resleeving All B-Series Engines $750.00 $750.00
AEM TRU-TIME CAM GEAR 1990-2001 ACURA INTEGRA (BLUE) $99.89 $99.89
Esslinger High Volume Oil Pump $75.00 $75.00
Esslinger Zetec 7310 Pistons - Sold Per Set $475.00 $475.00
Esslinger Zetec 7320 Rods - Sold Per Set $793.50 $793.50
AEM TRU-POWER PULLEY KIT 1994-2001 ACURA INTEGRA VTEC (BLUE) $150.01 $150.01
Esslinger 7242k Racing Dual-valvespring set w/ Titanium retainers $266.00 $266.00
A'PEXi AVC Type-R turbo boost controller (digital) (previously - 420-A004) $574.59 $574.59
Blitz Injector 700cc Top Feed (Honda & Mitsubishi) $113.85 $113.85
HKS External Fuel Pump 132psi / 65 gph $594.69 $594.69
AEM HIGH VOLUME FUEL RAIL 1994-2001 ACURA INTEGRA B18 SERIES (BLUE) $139.96 $139.96
AEM ADJUSTABLE FUEL PRESSURE REGULATOR HONDA/ACURA (HOLES INLINE) BLUE $176.49 $176.49
A'PEXi VTEC AFC (digital) $401.03 $401.03
HKS TURBO TIMER TYPE 1 (BLACK U.S. SPEC) $157.45 $157.45
HKS Turbo Timer Harness Universal application harness (3-pin female) $12.30 $12.30
DC Sports Ceramic Coated Headers 1994-2001 INTEGRA GS-R $337.46 $337.46
Overboost Stage 2 Gen III +100 HP Turbo Kit 1994-2001 Acura Integra GSR $5,045.95 $5,045.95
Blitz Super Blow-off Valve DD Universal $211.50 $211.50
HKS Intercooler Core #2 (400mm x 128mm x 65mm) $459.35 $459.35
Rev Hard Intercooler End Tanks $50.60 $50.60
HKS Standard Wastegate - 20.0 psi 1.40 kg/cm² (Purple) $344.51 $344.51
Innovative Pro-Gate Adapter $95.00 $95.00
Auto Meter Ultra - Lite 2-1/16"" Air Fuel Ratio (E)(Silver) (4375) $65.55 $65.55
Auto Meter Ultra - Lite 2-1/16"" Vac/Boost 30In Hg/30PSI (M)(Silver) (4303) $59.22 $59.22
Auto Meter Ultra - Lite 2-1/16"" Exhaust Temp 1600°F (E) (4343) $130.44 $130.44
Auto Meter Ultra - Lite 2-1/16"" Nitrous Press 1600 PSI (M)(Silver) (4328) $90.01 $90.01
Auto Meter Ultra - Lite 2-1/16"" Water Temp 120°-240°F (M)(Silver) (4332) $74.48 $74.48
Auto Meter Ultra - Lite 2-1/16"" Voltmeter 8-18 Volt(Silver) (4391) $44.04 $44.04
MSD-6AL, high performance with rev control 4-6-8 cyl $366.71 $366.71
MSD Ignition wire set, Super Conductor, Toyota Corolla/Geo Prizm, 1.8L DOHC $76.62 $76.62
HKS Iridium Super Fire Racing Spark Plug, SI-Series Heat Range "8" (Priced Individually) $28.71 $229.67
AEM COLD AIR INDUCTION SYSTEM 1994-2001 ACURA INTEGRA VTEC (BLUE) $220.89 $220.89
Excelon Nightbreed Glowing Sport Pedals Blue (M/T) $24.00 $24.00
Corbeau 2" Harness Belt Blue 4-Point Bolt In $69.00 $138.00
Corbeau Seat Bracket Drive Side 94-01 Acura Integra - Tab Slider $78.50 $78.50
Corbeau Seat Bracket Passenger Side 94-01 Acura Integra - Tab Slider $78.50 $78.50
Sparco Aluminium Shift Knob (Blue) $38.50 $38.50
STREET GLOW 15" Neon Accent Kit - Single - 150mA - YELLOW $27.60 $55.20
STREET GLOW 9" Mini Neon Accent Kit - Pair - 150mA - YELLOW $49.69 $99.38
STREET GLOW 2" Headlight Strobe Kit - Pair - 200mA - YELLOW $40.54 $81.08
Lexus Style Tail Lights 1994-2001 Acura Integra 2 Door $259.99 $259.99
STREET GLOW Gold-Line Series Neon Under Car Kit - 4pcs 2x54" & 2x30" - Power Output 2.8A - With 9500V Transformer - YELLOW $210.83 $210.83
NEUSPEED COILOVER 1994-2001 ACURA INTEGRA ALL (EXC.TYPE R) $992.39 $992.39
Suspension Techniques F&R Sway Bar Kit 1994-01 Acura Integra 2/4DR All, 1992-95 Honda Civic (w/ Original Front Bar), 1993-97 Honda Del Sol (w/ original front bar) $269.99 $269.99
Volk Racing TE37 18x9.5White (5 Hole) $582.95 $582.95
DTMAutohaus Carbon Fiber Hood 97-01 Acura Integra ALL $495.00 $495.00
Ignited Push Button - Blue $64.95
$59.95 $59.95
AEM 4 PISTON CAL. BRAKE KIT, 92-00 CIVIC EX, 92-95 CIVIC SI W/ ABS, 99-00 CIVIC SI, 90-01 INTEGRA (EXC. TYPE-R) BLUE $1,570.99 $1,570.99
NOS Nitrous System - Kit for most Fuel Injected Applications - 1.5L - 2.3L $564.50 $564.50
Auto Meter Sport - Comp 5"" Silver Shift-Lite Tach 10,000 RPM (E) (Silver) (3911) $229.68 $229.68
Corbeau Carrera (CR1) Yellow Cloth Racing Seat $399.00 $798.00
EXCELON BRIUS HYPER WHITE HEADLIGHT BULB (PAIR) H7 $15.95 $15.95
Sub Total: $21,096.70
Total: $21,096.70
and the body kit.......
please tell me what you think of my selection!!!!!
Old Mar 8, 2003 | 04:44 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Honestly, I would save up for a different car since it looks like you want to make some serious power (WRX STI comes to mind). Don't get me wrong, I love my car, but I would never ever ever even think of sinking $21,000 just to sit at a stoplight and smoke my front tires at 1/3 throttle.
But, in regards to that list, I have some quick changes:
Kaaz LSD -> Change to a less-maintenance-demanding Quaife unit.
AEM Cam gears -> These have a bad history of slipping. Try some Skunk2s.
Overboost Stage II Turbo kit -> WAY overpriced. Find another cheaper unit somewhere else.
AEM Cold-Air-Intake - You do know this won't work with your turbo kit correct?
AEM Big Brake Upgrade -> Try looking at the Wilwood kit instead.
You'll definitely need to budget some of your funds for 2-3 hrs of tuning on the dyno. Rates for tuning usually run anywhere from $150->$200. I would recommending ditching that Apexi V-AFC unit for a Hondata (pricey though).
Warning on the NEON streetunderglow kits -> make sure the housing is reinforced, unless you want a rock on the freeway to render it into 923 pieces.
Good luck...
Shingo
Old Mar 8, 2003 | 04:54 PM
blureintegragsr
thanx thats what i needed...but i wanna like blow peeps away w/ my car looks and performance wise
Old Mar 8, 2003 | 05:03 PM
Shingoblade-GSR
Hellsing Agency
One more recommendation: ditch the neons and save up for some real HID's.
Shingo
Old Mar 8, 2003 | 05:15 PM
blureintegragsr
like the ones in the car too?
Old Mar 8, 2003 | 05:20 PM
Snoopy's Avatar
Snoopy
been there done that
wow thats a big list
Old Mar 8, 2003 | 07:11 PM
reno96teg's Avatar
another e-dreamer..
Old Mar 8, 2003 | 07:30 PM
g2tegls's Avatar
g2tegls
MR, ftw
cliffs notes please :chuckles:
Old Mar 11, 2003 | 01:45 PM
ambition's Avatar
ambition
StillDPG
don't forget labor$$$$$ good luck.
Old Mar 11, 2003 | 02:41 PM
peiqinglong's Avatar
peiqinglong
Interesting car in the sig...any other pics?
BTW...wow...that is a long list and a lot of money to spend...good luck!
