Car trouble
Old Mar 7, 2003 | 09:33 PM
GreenEggs248's Avatar
GreenEggs248
Default Car trouble
My car started to act up last week. First off it's a man 94 Teg GSR with only an exhaust and intake.
1. No engine codes
2. New air filter
3. New fuel filter
4. New plugs
5. Change oil and filter
Looked at distributer . Opened it up and it looked fine. No charring.
Tried new plug wires.
It idles fine.
But when I drive it, it sounds funny until 2k rpm and then it's fine.
Same problem for each gear. Checked timing with a timing gun. Lokks like the computer is trying to adjust, not stable. And just pulled the plugs, they look like I'm running rich and lean. Does that make sense.
Any help, or if someone had similiar probs would be appreciated..
Could it be a bad ecu?
Thanks
Old Mar 8, 2003 | 08:32 AM
Charged-GSR's Avatar
Charged-GSR
check you fuel pressure the regulator may be ruptured and the fuel pressure is too high?
Old Apr 11, 2003 | 01:18 PM
GreenEggs248
Just checked the fuel pressure regulator...it works like it is supposed to
Old Apr 11, 2003 | 06:32 PM
Tobra's Avatar
Tobra
Assuming you have already done the disconnect the battery reset the computer thing, it sounds like a spark thing. Maybe a rotor, cap; they can look pretty good and still be bad. What does that mean when you say it is rich and lean? Fouled and burnt?
Old Apr 14, 2003 | 05:36 AM
GreenEggs248
The plugs show both examples of running rich and lean. Strange? I'll try to get a pic. I'm going to pull the valve cover to check the timing belt, but I'm running out of ideas. Want to check the ecu, but it is so difficult to find someone who as an ecu to swap with. Thanks for your help.
