what is a flex pipe?
It's a braided or spiraled steel section that can be bolted or welded into an exhaust system. The purpose of it is to maintain a leak-free exhaust system while accounting for engine movement that usually occurs in higher output applications.
Here's an example of the braided style:
And here's a shot with both styles in one photo:
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
Originally posted by pSiRacer92
my car came stock with a flex pipe i thought all cars did
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
Originally posted by -KangaRod-
so will things break if you don't use one?
You need a flex connection if you bolt the exhaust system to the car. That includes pretty much any transverse motor setup, unless you're using solid motor mounts & torque strap mountings (read: "not for street use"). Don't confuse braided flexpipe with the cheap corrugated type! Corrugated is for half-assed installs, and can't handle continuous flexing. Use the braided kind.
