****ty Reception
Old Jun 20, 2002 | 05:23 PM
mphurley's Avatar
mphurley
Default ****ty Reception
I got a new JVC cd reciever installed today. My reception was really ****ty with the stock radio, so i hoped a new head unit would help it. BUT, i still get really bad reception. So i guess i need to look at replacing the antenna. Is this a simple task or do i have to run a whole new wire from the deck?
Old Jun 20, 2002 | 05:39 PM
crucial Si's Avatar
crucial Si
Banned
Default Re: ****ty Reception
you have to run the whole wire from the head unit to the antenna
Old Jun 20, 2002 | 06:37 PM
str8edgexx's Avatar
str8edgexx
are you sure you have a good connection between the antenna wire in the back of the deck and the actual antenna on the roof? Sounds like something is loose. I'd look into that before putting in a whole new antenna
Old Jun 20, 2002 | 06:50 PM
mphurley's Avatar
mphurley
I know theres a good connection going into the back of the radio. Is there somewhere else to check?
Old Jun 20, 2002 | 06:54 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Can't you get antenna boosters?
Old Jun 20, 2002 | 07:00 PM
mphurley's Avatar
mphurley
Yea i was thinking about getting a booster...but it should be picking up more then one station. We have dozens of stations around here it should be able to pick up. The one it does pick up is right down the road. Even the display radios at best buy pick it up with out an antenna plugged in.
Old Jun 20, 2002 | 07:39 PM
varyda's Avatar
varyda
take that JVC sh.t back to the store and getyourself a nice new alpine deck and XM.... then you can also get rid of that nasty ass looking antenna as well and have 100% digital radio
Old Jun 20, 2002 | 07:54 PM
mphurley's Avatar
mphurley
this radio does have XM capabilities, its the JVS KD-L1000. Its a sweet deck. I got the antenna problem fixed though. Down by the steering column i found where the coxial cable came in from the antenna and followed it until i came across a place where it plugs into what seems to be an extender. I unplugged it and plugged it in again, but didnt work....then i pulled it out a little and turned it and bingo the reception picked up. Then just carefully pushed it back up into place.
Old Jun 20, 2002 | 08:13 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
I'll copy this to audio forum for ya
Old Jun 21, 2002 | 05:35 AM
Bl@ck's Avatar
Bl@ck
Sinner
i agree, jvc decks aren't that great. sure they usually have a lot of features, but the quality isn't up to par as far as i'm concerned. i had a jvc deck and it lasted about a year. if i shell out $300+ for a head unit i expect it to at least last more than a year.
