rotors
Old Jan 31, 2003 | 01:03 PM
jamal531's Avatar
jamal531
Default rotors
Wzup yall.....Does anyone have a DIY on how to put on brembo rotors and aem pads on a 5th gen accord ex? i would love to get these on soon......HELP!!!!
Old Jan 31, 2003 | 10:09 PM
LocaL raCer's Avatar
LocaL raCer
R.I.P. Kato-san
do a search in the accord forum, this has been gone over numerous times....
Old Mar 16, 2003 | 10:19 AM
jsinger's Avatar
jsinger
IH8S810
I know it's been awhile since this was posted.. but if it helps...I just had mine put on. I tried twice to do it myself and I got everything off but the rotor. The rotors are hydraulically pressed on, and need to be taken to a shop. Unless of course you have the tools and knowledge to do such work.
Old Mar 16, 2003 | 08:11 PM
faded's Avatar
faded
basically and briefly its:
remove the 2 (12mm if i remember) bolts holding the caliper on
remove the 2 (may need to be drilled out) screws holding the rotor on
hammer the rotor off
put new rotor on and reinstall in reverse order
should take about 30 minutes at each corner with hand tools and a jack
