HELP can not fix this idle problem clip inside
Old Jun 21, 2009 | 01:00 PM
Sleeper00's Avatar
Sleeper00
Default HELP can not fix this idle problem clip inside
92 h22a accord, i did search and did alot of stuffs but still can't fix this idle problem, that's y i made a clip to show it
ivac-cleaned
fitv-adjusted
dis cap and rotor-new
motor mounts-filled with 3m
egr vavle-cleaned, egr ports not clean yet
thank you
this is with a/c ON
Old Jun 21, 2009 | 03:47 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
low coolant or vacuum leak
Old Jun 22, 2009 | 07:55 AM
Sleeper00's Avatar
Sleeper00
i did change some vacuum hoses, but i will check the coolant level, thankx
Old Jun 29, 2009 | 05:27 AM
Sleeper00's Avatar
Sleeper00
problem solved
Old Jun 29, 2009 | 02:51 PM
94jdmcivic's Avatar
94jdmcivic
what was it?
Old Jul 14, 2009 | 02:43 PM
93green.vtec's Avatar
93green.vtec
Default brakes prelude curse.
My h22 has several problems .
1. Brake pedal goes to floor when cars warm and at stoplight
fluid level normal.
2. The Abs light goes on randomly been able to reset by
pulling fuses .
3 The prelude curse is real and never ending very fun car nevertheless.
