p1259 vtec system malfunction
Old Jun 13, 2009 | 04:51 PM
blacklude's Avatar
blacklude
Default p1259 vtec system malfunction
my prelude 5th gen threw a code p1259. i have a vtec controller, my oil level is good and vtec engages. what could be the cause. does anybody else have a vtec controller and have this problem. whats the min rpm to have vtec come on with a vtec controller.
Old Jun 14, 2009 | 12:34 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
It makes no difference at what RPM vtec engages...take off the controller and see if that fixs the problem..if not you need a new selonoid
Old Jun 20, 2009 | 08:43 AM
cruzalekz's Avatar
cruzalekz
dont change the solenoid since you mentioned the vtec engages.
you have a wiring problem wherever you tapped the vtec controller. basically your pcm is seeing that your solenoid is not working
Old Jul 16, 2009 | 04:43 PM
blacklude's Avatar
blacklude
its been a couple of weeks and with vtec settings oem, no malfunctions. does anybody know how low i can set my vtec controller without setting a dtc.
