TSX torque
Old Jan 29, 2003 | 11:22 AM
linhnail's Avatar
linhnail
Default TSX torque
I know that the TSX have about 166ft-lbs torque and the Accord have about 212ft-lbs torque and the RSX have about 145ft-lbs torque. So which one is faster and better??? is the lower ft-lbs torque is better?? what is ft-bls torque can anyone help me please. thank you
Old Jan 29, 2003 | 11:52 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
First off, welcome to H-A.Net
Well, obviously the more torque the better. However, it can be decieving, just like horsepower. Horsepower is usually the greatest indicator for how fast a car is, and torque is the greatest indicator for how easy it is to drive the car at low RPMs.
http://www.howstuffworks.com/fpte3.htm
Go to that website, and if you have some questions that are more specific please tell me
As far as what's fastest between the Accord V6 automatic, Acura TSX 6 speed, and Acura RSX-S...the TSX should be a bit faster than the Accord but slower than the RSX-S. But this car has much more to offer than the RSX-S, so they really do not compete in any way.
Chris
PS - Are you trying to decide which car to buy?
Old Jan 29, 2003 | 09:40 PM
linhnail's Avatar
linhnail
Default But
the TSX have only 200hp and the Accord have 240hp how come the TSX faster??? and the RSX-S have 200hp as the TSX but the torque is only 145lb-ft compare to the TSX 161lb-ft, how can the RSX-S faster??? Also which car is better as in overall score, since the price between the TSX and the accord is about 25k
thanks
Old Jan 30, 2003 | 05:27 AM
98CoupeV6's Avatar
98CoupeV6
Default Re: But
thanks
The TSX may have fourty less horsepower, but it is going to weigh about 300-400 less pounds and will have a 6 speed manual transmission, which will give it a decisive advantage over the 5 speed automatic in the Accord. The RSX-S is even lighter than the TSX and has shorter gearing, making it even faster.
Which car is better? It depends on your perogatives. The Accord is large, luxurious, and has a torquey engine. The RSX-S is small, kinda bare bones (well, at least compared to the others), handles like it's on rails and has a boy-racer small 4 cylinder that only makes power at the top of its rev range. The TSX is a smaller version of the Accord and will undoubtedly have better handling and be far sportier than it, but will retain all of its luxury features and then add some.
Please tell me if you have any more questions or if I didn't explain it well
Chris
Old Jan 30, 2003 | 11:42 AM
kazi's Avatar
kazi
Toyota Racing = Cheaters
There's just to many factor in a car's speed. Tires, total weight, weight distribution, gearing, FWD/RWD/AWD, etc.... Just don't take HP and TQ numbers as the sole measurement of estimating speed.
Old Feb 6, 2003 | 08:54 AM
VTECseoul's Avatar
VTECseoul
i love my wife's (y)
you see proof in front of you that AUTOs are slow, 1st gear in AUTOs are very tall. in comparison w/ 6th gen Accords 2.3L, the 5spd shifts at 30?mph & the SLOWmatic shifts at 35; the 1st 1/2 of the powerband is so weak that the sooner you get to the 2nd 1/2, the more advantage you have.
0-60mph is hard arguement for 6spds, becuz most Co.s gear the car's for fastest time w/ just 2 gears so they in relation are almost the same as 5spds. that 6th gear is mostly for fuel economy, not power. if you find a car that shifts into 3rd before 60mph, like the Celica GT-S, then that car was engineered to keep the gears within the powerband for drivablity, not all out speed.
Old Feb 13, 2003 | 03:06 PM
Type V's Avatar
Type V
it would be interesting to see the battle of the 6spds:
RSX-S
TSX
Accord Coupe V6
