Help with egine...running on 3 Cyliners
Old Jun 19, 2002 | 01:59 PM
aznbruce74's Avatar
aznbruce74
Default Help with egine...running on 3 Cyliners
I have a 1991 Acura Integra, only 140,000 miles. My car is running on 3 cylinders and oil is leaking from the oil drain plug. My friend, he's pretty good mechanic says to change the spark plugs. I found the last spark plug wasn't firing. After I changed all the plugs, same problem. Next, he says it could be the Fuel Injectors. I ordered some Venom Injectors and replaced them. Still the same problem. N/E body know what could be the problem? Thanx....
Old Jun 19, 2002 | 03:12 PM
MaliceGSR's Avatar
MaliceGSR
Super Saiyan
check distributor?
Old Jun 19, 2002 | 03:15 PM
Excelesor's Avatar
Excelesor
Platinum Member
have you taken a compression test yet?
Old Jun 19, 2002 | 03:51 PM
antarius's Avatar
antarius
Large Member
coil, wires, distributer,
Old Jun 19, 2002 | 05:43 PM
aznbruce74's Avatar
aznbruce74
I think I'm going to take the car for a compression test. Well I live 5 minutes from King Motorsports. So, going let them check it out. I'll know for sure. My friend says it not good driving it, I'm dad's gheto ride for now. Thanx Yall...
Old Jun 19, 2002 | 06:02 PM
qtiger's Avatar
qtiger
I'd try wires next.
Old Jun 19, 2002 | 06:29 PM
90'RS's Avatar
90'RS
The compression would have nothing to do with the car only firing on 3 plugs...I would change the wires and then check the coil.
Old Jun 19, 2002 | 08:24 PM
sid's Avatar
sid
Are you getting any white or black smoke out of your exhaust? If not it's most likely going to be electrical.
Old Jun 19, 2002 | 09:25 PM
yianni64's Avatar
yianni64
Steal some Mugen stuff while you're there
virgil73542
CL, TL, TLX & Vigor
6
Aug 28, 2005 06:45 PM
Whitelude420
Prelude
May 27, 2003 05:20 AM
