BUSTED NOS Hose
Old Jan 15, 2003 | 04:00 PM
drag_civic_si's Avatar
drag_civic_si
Default BUSTED NOS Hose
Ok, so I hooked up my nitrous earlier and when I had everything run, I went to test it and make sure that everything was working properly but as I turned on the bottle I heard a leak and traced it down to about midway through the stainless hose. I was curious if there is anyway that the metal could be cut and pulled back and then repair the rubber hose? I am just really not in the mood to go and waste a lot of cash on a new hose when I haven't even had the opportunity to use it.
Old Jan 15, 2003 | 08:46 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If you cut it where it's leaking, you could get a union and some more fittings and essentially screw the two sections of line back together.
Old Jan 15, 2003 | 11:23 PM
dubcac's Avatar
dubcac
I
Yep. You can cut it and use fittings, or buy a new line.
