'95 Sol Speaker rattle/vibration
Old Mar 18, 2009 | 02:46 PM
delwetwillysol's Avatar
delwetwillysol
Default '95 Sol Speaker rattle/vibration
I own a 1995 Del Sol, and I'm in a constant battle with my speakers. The speakers are all good, as far as I can tell. In fact, the ones in the door panels are only a few years old. Problem is, they all rattle and vibrate pretty bad with loud and bass filled music. I love listening to my music in this desired manner, but, can't stand all the vibrations. It's kind of embarrassing, too. Any suggestions on how to fix this problem. Need help with the back and side speakers. I keep the passenger side seat up against the back speaker/back glass housing; so, it isn't quite as significant of a problem. PLEASE HELP!!!
Old Mar 18, 2009 | 05:01 PM
94jdmcivic's Avatar
94jdmcivic
if i were you i would just get some better speakers. If they are factory...they arent meant for heavy bass or any of that but if you bought cheap speakers from somewhere then you also wont get good quality out of them
Old Mar 19, 2009 | 05:29 AM
dieneverknowing's Avatar
dieneverknowing
If you're sure the speakers are fine and of decent quality, then I would look into getting some sound dampening material. Take off your panels and roll it on and see if it works. If it doesn't then you either have some loose panels or your speakers are gone.
Old Mar 19, 2009 | 09:18 AM
delwetwillysol
Yeah, the speakers seem fine. I saw some stuff on Crutchfield... Dynomat padding. Seems like a good fix!
Old Mar 19, 2009 | 10:35 AM
mattc28's Avatar
mattc28
Why dont u change the bass/treble levels or the equalizer presets to one where you can turn it up loud enough for you, but it doesnt make all the noise... you shouldnt need dynamat unless you have very expensive audio equipment
Old Mar 19, 2009 | 12:34 PM
delwetwillysol
The presets have been fooled with constantly... I have them set to what I like, and hate changing them. Plus I don't just listen to one kind of music. When My iPod is on random, I find myself having to adjust the volume for different songs. It just gets really annoying having to make adjustments like that. If at all possible, I'd like to find a more permanent solution. Been dealing with this for years. Besides. Whether the equipment is expensive or not; If that dynamat stuff works to stop vibrations, then, that's probably the most effective idea.
