biggest bore size?
Old Dec 30, 2002 | 01:07 PM
Snoopy's Avatar
Snoopy
been there done that
Default biggest bore size?
what is the biggest you can bore out a b18c block safely without running into problems?
Old Dec 30, 2002 | 01:31 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
On the stock sleeves? Not much. With some aftermarket sleeves you can go out to 86 mm.
Old Dec 30, 2002 | 01:49 PM
jfdmas's Avatar
jfdmas
I don't recommend more than 81.5 mm.not much at all..
Old Dec 30, 2002 | 08:11 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
what about stroker stuff. Can you get a stroker kit for the GsR? Some time down the road I'm thinking about a bored-stroked GsR..
Old Dec 30, 2002 | 10:36 PM
qtiger's Avatar
qtiger
Yes, but stroker kits are so much more expensive than getting a block resleeved I'm not sure why you would consider it unless you were planning on doing both.
