92 Honda accord suspension and steering issues...
Old Oct 28, 2008 | 06:29 AM
650SuperJet's Avatar
650SuperJet
Default 92 Honda accord suspension and steering issues...
I have a 1992 honda accord that likes to vibrate the steering wheel when the brakes are applied. Sometimes its worse than other times. It seems to only vibrate at a certain brake pressure. What can I check? Also...I just developed a squeel in the front end when turning the steering wheel. Anything common on these cars?
Old Oct 28, 2008 | 01:41 PM
Cousin It's Avatar
Cousin It
Vibration in the steering wheel when you apply the brakes is most likely a warped rotor.
Old Oct 28, 2008 | 04:30 PM
94jdmcivic's Avatar
94jdmcivic
my civic did that when i got some new tires. It would do the exact same thing and it was that i needed to get the wheels balanced. its real cheap and i would try that. ALso the turning issue is probably your dust shield touching the rotor, i also had that same problem. All i did was bend it backwards and it quit. Try that and let us know what happens
Old Oct 28, 2008 | 05:25 PM
A-series's Avatar
A-series
v-card member alpha
If it's only when you apply the brakes, most likely warped rotor(s) in the front (since you feel through the steering wheel). If you feel it w/o applying the brakes, I'd lean towards unbalanced wheel or a damaged/failing tire.
