where can i get this..pic inside
Originally posted by KRA
that is damn tricky.. just get an old honda deck and cut the front off?
yeah, thats fabricated... dosent do too much in that car though, the friggen monitor sticks out too much, so a real thief can see that its just a stick-on security cover. That, and the deck below it stands out like a sore thumb.
the pic was from sound domain. could it be the same guy?
cutting off the stock deck? doesn't sound too pleasant.
i think it looks damn real especially at nite when the light is dim. i really want to know where i can get it and meanwhile i will be searching around for it and post the result ASAP.
im not sure if u need to cut it off, it may just pop off depending on your car. I installed a deck in my ex's 97 civic ex that had factory keyless alarm & she wanted to keep it. part of what i had to do was keep her factory deck along with the aftermarket deck in her car. the face on her factory deck just popped off w/ a flathead screwdriver. (i had to do this in order to fit the factory deck behind the dash)
edit: when u pop it off, there is a connection that you have to carefully remove from the chip inside the deck
edit: i think i figured out how this can be done...i took a look at my factory cd player(double din size) and saw there are two screws holding the face cover. i took the screws off and tried to pop that thing out with NO SUCCESS. that is damn tight. thanx for the reply guys
yeah the one i did was a cassette so im not sure. sorry, i had forgot about the 2 screws, but yeah it took me a few minutes to figure out how much force i should use in prying the face off. i think i ended up breaking a plastic clip off while doing so.
