Give me some head ... info
Old Dec 10, 2002 | 05:04 PM
The Bum's Avatar
The Bum
Black people go wooooo
Default Give me some head ... info
Ok, go ahead and run off all the upgrades you can do to a head and WHY they help...
IE, whats the purpose of retainers, new springs, why a 5 angle valve job is better than 3....
Just run off whatever you want.
Old Dec 10, 2002 | 06:26 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
New valve springs are generally stiffer to help prevent valve float with cams that generate more lift.
Titanium retainers are lighter than stock to help the motor rev up a bit quicker, and are stronger to cope with the stiffer valve springs.
5 angles instead of 3 when doing a valve job produces more finely curved seats.
Is there any overall goal you'd like to produce?
Old Dec 10, 2002 | 07:23 PM
The Bum's Avatar
The Bum
What is the job of the retainer?
And you woundn't want new springs and retainers unless you got new cams, im assumming...
Old Dec 10, 2002 | 09:59 PM
qtiger's Avatar
qtiger
5 angle job isn't necessarily "better" than 3. Especially on a Honda head where there isn't a lot of material to work with.
Old Dec 11, 2002 | 06:23 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
The retainer is the cap piece that [along with the keepers] form a taper fit place for the top of the spring to press against. And no, you generally wouldn't want new springs and retainers unless you went with wilder cams.
Also, qtiger's right, a 5 angle valve job usually causes more chance of wiping the valve seat, or cracking a valve near the edge since the number of angles cut into the valves mean that the edges are normally thinner.
-Harry
AIM: NDcissive
Old Dec 17, 2002 | 02:46 PM
sunshine's Avatar
sunshine
Torqueless Wonder
Milling is fun. Increases compression by decreasing the size of the combustion chamber or moving your head closer to the piston top. Either way it ups your comp, but too much of it will retard your camtiming negating the milling process and possibly making your car run like ass.
Old Dec 17, 2002 | 05:00 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
It also moves the valves closer to the pistons, so you have to be careful how much you mill off the head. You don't want the pistons and valves getting too friendly with one another...
Old Dec 18, 2002 | 08:31 AM
sunshine's Avatar
sunshine
Torqueless Wonder
hehhehehehe, i bent valves once...
