I kept blowing fuses for my turn signals...now it doesn't work at all
Old Sep 19, 2008 | 06:39 AM
93hondablk's Avatar
93hondablk
gtr
Default I kept blowing fuses for my turn signals...now it doesn't work at all
almost everytime I use my turn signals I would blew the fuse on my 90 crx. I tried every type of fuse 10's 15's 20's still the same results. But now this time when I was driving yesterday I turned on the turn signal and it didn't work but this time it didn't blew the fuse. The fuse is fine but none of the signal lights are working. I check for other fuses and the hazard fuse was blown. I replaced it but still no signals. All fuses are fine but none of the signal lights are working. All other lights work.
Old Sep 19, 2008 | 08:55 AM
ChrisS's Avatar
ChrisS
More than likely, one of your turn signals is shorted out. You'll have to trace turn signal wires looking for the short.
(note: The turn signal fuse is 10A. Don't use higher amperage fuses to "fix" a problem that will only cause more damage to the wiring.)
Also check:
-the turn signal/hazard relay
-the bulbs in the turn signals (are they the correct bulbs?)
-is there a short in one of the bulb sockets?
Last edited by ChrisS; Sep 19, 2008 at 08:08 PM. Reason: added more checks for potential problems
