Rough Idle, lost power legend 94
Old Apr 27, 2008 | 04:03 PM
Legend007's Avatar
Legend007
Default Rough Idle, lost power legend 94
Anyone know what causes the legend rough idle? How to check? When in gear, sometimes the engine lost its power, rough idle.
How to fix the problems?
Old May 3, 2008 | 07:51 PM
ari_one's Avatar
ari_one
There can be many possible problems, including air in the system.. bleed then bleed and then bleed again. After that it gets problematic, it could be a vacuum leak, bad coil pack, bad igniter, bad plug(s), IACV......
Old May 11, 2008 | 07:45 AM
Legend007's Avatar
Legend007
I did a search and did some clean up the IACV, it improves idling. I found a lot of stuff blocking the filter. Still not fully cure the problem, I have next plan to clean the EGR valve, and chang the spark plugs. Any recommedation?
I wonder what is the RPM when it's idling? anyone know? my is about 750 rpm.
Old May 11, 2008 | 09:24 PM
ari_one's Avatar
ari_one
Idle RPM:
Manual 650 +/- 50
Auto 600 +/- 50
