[enquiry]civic Eg6 Ecu With Tcs
Old Apr 26, 2008 | 10:27 AM
llllllyyy's Avatar
llllllyyy
Default [enquiry]civic Eg6 Ecu With Tcs
Can anyone provide me with the ecu codes for Manual EG6 SIR2 with TCS year 1992?P30-XXX. What are the XXX?
Cause there are alot of different types of P30 out there so I dont know which to take.
Earlier I tried several p30 ecus from manual eg6 without tcs and abs. The rpm wont work. So I checked with several people,they already said , ecu without tcs cant put in eg6 with tcs or else rpm meter wont work.
Old Apr 26, 2008 | 12:55 PM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
i wouldnt of thought it would make a differance, as i thought the tcs read from the abs sensors
Not definate though. sorry cant be of more help
Old Apr 26, 2008 | 03:40 PM
llllllyyy's Avatar
llllllyyy
Yeap. TCS and ABS works together with their own com system.
But an EG6 tcs manual ECU
Check how the dash is getting the rpm signal. Normally it receives it from the ignitior, but with this EG6 it might be reading it via the the ECU. The reasoning is that if the TCS cuts ignition then the ignition signal will cause the tach to jump around. I don't see why you shoud not be able to switch the dash over to the ignition signal if not using the TCS.
Taken from another forum.
So actually I got 2 ways to solve my problem.
1. Get an ecu with tcs that costs twice the price of one without.
2. Direct the rpm signal from the ecu harness all the way to the meter cluster.
But right now I am slightly towards option 1 only I dont know the ecu ID.
P30-XXX. XXX=?
