check engine light come on and off
Old Oct 31, 2002 | 03:06 PM
dynomax27's Avatar
dynomax27
Default check engine light come on and off
Just installed a custom turbo kit for my civic. im running 8psi and the vafc hack w/ dsm injectors. Well im driving it today and there is no check engine light on so im happy. When it got dark, i wanted to see how hard it pulled. So i drove the car hard. Went up to about 80mph from a stop. it pulled pretty nice and the check engine light wasnt on. Then about 1 minute later im going about 40, drop it to second, it pulls hard, i redling, shift, then at about 80 mph while im still gunning it, the check engine light comes on and my car stopped accelerating. i felt a force on my gas petal, and i couldnt floor it. Does anyone know why this happened. Its happend before too but i dont know why.
Thanks
Old Oct 31, 2002 | 03:16 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Did the CEL come on while you were going uphill under light throttle? If it did, that's common with the hack. Since the MAP voltage varies about 40% from the reading that the barometric sensor in the ECU puts out, the ECU assumes the baro sensor is faulty and throws a baro sensor code(13). This usually happens under light-throttle, going uphill. Or, if you're redlining frequently in a short period of time, it might be a 22, which is the VTEC solenoid.
Old Oct 31, 2002 | 04:22 PM
dynomax27's Avatar
dynomax27
Well i was redlineing frequently. About say 5 redlines in 1 minute. What can i do. So is it normal for the car to just stop accelerating while im flooring it due to the code.
Old Oct 31, 2002 | 06:44 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Something tells me it was a 16, which would explain a lot...
Old Nov 1, 2002 | 04:55 AM
dynomax27's Avatar
dynomax27
Hey thanks a lot. I checked for the code and it was a code 16. Darn fuel. Ill check the resistors for bad connections. Good diagnostic Inspyral.
