why would they do this?
Old Oct 25, 2002 | 04:44 PM
taylormadem5's Avatar
taylormadem5
Default why would they do this?
why would TODA make there cam gears "kill the I in i-vtec, http://www.todaracing.com/products/h...ampulleys.html . they say in there description that those cam gears, "The TODA VTC Killer campulleys eliminate the VTC function of the K20A engine. Essentially, they remove "i" from i-VTEC." what the hell is that about,
Old Oct 25, 2002 | 07:09 PM
Shea-bird's Avatar
Shea-bird
haha, a lot of people don't like the i(intelligent) aspect of vtec because it is for gas mileage and the transition is much smoother. There is probably more power to be had with-out the i aspect of vtec... just my 2cents
Old Oct 25, 2002 | 07:23 PM
taylormadem5
interesting, but makes sense. i guess fast cars arent meant to get good gas mileage, lol
Old Oct 25, 2002 | 09:09 PM
ClearLakeRSX's Avatar
ClearLakeRSX
I think those gears will eliminate VTEC by permanently putting you on VTEC, they get rid of the lower lobe and your car only runs on the high lobe, it makes for a car thats not too streetable.
Old Oct 29, 2002 | 10:17 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The VTC part of i-VTEC controls the cam phasing. The stock cam gears are continuously adjustable by the ECU. You get the Toda gears, and the ECU no longer plays with the cam phasing and instead you have regular old adjustable cam gears. The best option would be to play with the cam phasing settings within the ECU since there definately is some power to be gained by doing so.
Old Oct 30, 2002 | 05:48 AM
taylormadem5
how would you be able to play with the ECU and the cam phasing. Hondata or some other piggy back system or what??
Old Oct 30, 2002 | 06:59 AM
BonzoAPD's Avatar
BonzoAPD
maybe because it doesn't have the kick as the earlier V-Tec engines
