Aftermarket Sleeves/Boring...Piston Preferences
My Acura Integra has the B18B1 Engine and I am looking to bore the cylinders....where can i find aftermarket sleeves that will fit my custom boring? I have checked all over and cannot find anyone who sells them. And what pistons would i get the most compression? Lookin to raise compression to 10.5:1
You have to sleeve first and bore later. Aftermarket sleeves can be bored from 81mm to 85mm.
Why would you want to raise the compression? 9:1-10:1 is the range you should be looking for turbo. If you are going N/A, you want much higher compression than 10.5:1.
Tell us what it is that you are trying to accomplish.
Taking in consideration what you said about the compression, would it be better to just run a turbo setup? Now can I still bore the stock sleeves?....Can I expect a power output range from raising the compression and boring the sleeves to be around or equal to installing a turbo setup? I am trying to build on my stock rebuilt engine and get all around great perfomance, some street racing and all time on demand power.
As far as your other questions, I can't understand what you are trying to say. You can't compare a turbo setup and a n/a setup...they are two completely different builds with two completely different powerbands.
