Long race, what engine mods so won't blow up?
Old Oct 16, 2002 | 04:55 PM
jwaked's Avatar
jwaked
Default Long race, what engine mods so won't blow up?
I just bought a 92 Civic HB with a 95 GSR Vtec engine. The engine is stock with 85,000 miles. I have a few Road Races coming up and the engine will be running mostly at high RPMs. What can I do to make it hold up just find with out blowing up or killing a cilinder?
Thanks
Jay
Old Oct 16, 2002 | 05:15 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Default Re: Long race, what engine mods so won't blow up?
Thanks
Jay
An Oil cooler with a thermostatic bypass valve and colder thermostat for your radiator will help you out a lot. Your biggest problems in a long race are overheating, tires and brakes. I'm assuming you already know to have the latter two in tip-top shape. My buddy rolled his '90 Corolla the other day at the porsche club race because his brakes bled off fluid and faded on him in a 70mph corner. Just a bit of friendly advice ya know.
Old Oct 16, 2002 | 07:29 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
A baffled oil pan would also be a good idea.
Old Oct 16, 2002 | 09:12 PM
qtiger's Avatar
qtiger
Given your signature, I'm going to assume you know all the race crap and just want the Honda specifics.
Hondas love high RPMs, and you don't really have to worry about any damage other than floating a valve, and that's only if you overrev the motor.
Baffled oil pan and a Fluidyne radiator would be my only advice.
Other than a fresh dose of all fluids, new plugs & wires, all the stuff the previous owner may or may not have tended to. The usual.
Old Oct 16, 2002 | 09:23 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Moroso makes a nice oil pan--I think you might be able to get it from Summit.
Old Oct 16, 2002 | 09:29 PM
dubcac's Avatar
dubcac
I
Mugen also makes a baffled pan for the GSR.
Team B.O.B.ź - Ballaz on a Budget
Old Oct 17, 2002 | 05:02 AM
jwaked's Avatar
jwaked
IŽll check for the baffled oil pan.
This is what I got so far to do:
Fluidyne Radiator
Baffled oil pan
Oil cooler
New hoses
New Fuilds with Red line Everywhere
Any more ideas? Should I get the GSR or the Civic Radiator.
Thanks guys.
Jay
Old Oct 17, 2002 | 10:53 AM
TheRooster's Avatar
TheRooster
Fluidyne Radiator
Baffled oil pan
Oil cooler
New hoses
Thanks guys.
Jay
Here's another one that I almost forgot. Ditch the green anti-freeze, and get some high-edurance red stuff. I read about it in Car & Driver a few months ago, and it has much better cooling properties than the green, and its been used in diesels for 600,000 miles, with the addition of inhibitors at 300k. I've got it in mine and have noticed the engine running cooler, longer, even with a brass radiator. (my aluminum one was finished.)
Old Oct 17, 2002 | 02:07 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
If you want your engine to run cool, completely remove your thermastat, when you do this, your engine will run the coolant all the time instead of just doing it when it starts overheating. My friend did it to his Camaro and instead of running at about 220 degrees, it runs at about 175 degrees. I don't know if it'll work on Hondas, so you might want to check with someone else that knows a bit more than me.
Old Oct 17, 2002 | 02:47 PM
inspyral's Avatar
inspyral
のんびり~(Žε`)
My cousin's DA Integra has been running w/o a thermostat since before the summer. It takes a while to warm up, but it runs a lot cooler. I bet it's gonna be a ***** waiting for it to warm up in the winter though.
