Del Sol Cutting out
I'm posting this for a friend. He has a 97 del sol 1.6 vtec. He replaced the plugs wires and fuel filter. It cuts out at random times not all the time. Every couple days it will do it 4 or 5 times then not do it again. Any ideas? My thoughts were replace the dizzy cap and rotor and if that didnt help i figured itd be the fuel pump
Do not replace anything until you check for loose grounds. I had a simliar problem and the culprit was a loose ground wire causing misfires.
