Del Sol Cutting out
Old Nov 28, 2007 | 07:05 PM
the0ne's Avatar
the0ne
Default Del Sol Cutting out
I'm posting this for a friend. He has a 97 del sol 1.6 vtec. He replaced the plugs wires and fuel filter. It cuts out at random times not all the time. Every couple days it will do it 4 or 5 times then not do it again. Any ideas? My thoughts were replace the dizzy cap and rotor and if that didnt help i figured itd be the fuel pump
Old Nov 29, 2007 | 09:16 AM
mberndt's Avatar
mberndt
Check all grounds...
Do not replace anything until you check for loose grounds. I had a simliar problem and the culprit was a loose ground wire causing misfires.
