97 civic for trade Built Motor, System,Fuel Managment
I have a 97 dx with a fully rebuilt motor, new high comp P29 pistons,water pump, timing belt, tensioner, ACL main and rod bearings, Newer Exedy stg 1 clutch and 7.5 lb fidanza flywheel with a 5spd ex transmission, i have a brand new d16y8 cylinder head with a p2p ecu and a Vtec selenoid that still need swapped, just need the intake manifold and a knock sensor to complete or sell the p2p ecu and buy a p28 and a obd1 conversion harness and it would be a better tune and not require a knock sensor, less then 1000 miles on the rebuild and its running strong, located in ohio and the biggest problem its a salvage, just figured id throw the offer out there, has a full system exhaust, aeromotive fuel management system, Kicker amp with 2 12'' Highfonics (competition) with a custom in trunk box, Flip screen Dvd Player, fidanza dual bend short shifter custom head liner and pillars, push button start (that works) and i know im forgetting more
Currently sponsored on http://www.carsponsors.com/96806
wheels are not currently on car, running on steelies
looking for only trades , located in ohio
