Old 80 cvcc civic new B16vtec
the paint is a rubber base paint- the mounts are for the 88-91 w/ b16 swap mounts and custom made to fit into the 80 civic the front trans mount was more on the custom fab. here are more on the mounts pics.
stuff i yet need to do is wiring a lill, i have most of it done it will start at the key but the heater and lights need to be done the motor is going back out for the rest of the paint its going white again the black is the rubber stuff like a primer coat then the inside will be back in like the seats and stuff i have not started yet but next day or so will start and the trac-bars need to be finished and set in hoses and other small stuff. i have alot of pics if the swap if anyone wants pics of something they wanrt to see ill post it.
here is the nice line up i did with laser light and level
here is the speed sens, i had to have for the ECU Vss was off the 88 civic put in the stock 80 cvcc cluster.
ok haven a lill fun with the RC car a buddy was maken fun and picked up the rear yes has the motor in still and still light like 1380 lbs w/ every thing in it seats and all.
