Hone and piston size
As long as you don't hone away too much material, you'll be fine using the stock bore pistons.
I wouldn't rev a stock B20 higher than the OEM rev limit without some modification, namely ARP rod bolts or aftermarket rods. If your having the block honed by a machine shop, OEM rings should be fine.
Be sure your ring gap is calculated correctly!
