Best tires for the Accord?
I think your asking about performance, and if thats the case what is your price range per tire?
The Traction T/A is a high or "ultra-high" performance all weather. I'm looking for a quiet ride, good handling 60 or 70K mile warranty type of tire. My driving style is "spirited."
I guess I should ask what everyone recommends. I'm familiar with several of the currently available brands and models. I just wanted to try and get a feel for what folks are thinking in general on the forum as far as a good tire goes.
Based on what I've seen so far at tirerack.com, I'd say that I'm looking in the $45-65 range.
Thanks.
Thanks.
Thanks.
Thanks.
Yes, round tires are good. Thanks.
I have been using the Traction T/As. They are OK; but seem to be really sensitive to tire pressures, which I actually can't tell if the wear is alignment or tire pressure related.
Anyway, they do come fairly well rated on tirerack and they are supposed to have a 60K mile warranty.
I'm just throwing the general question out there...
Thanks again.
Thanks again.
There are very few V let alone Z rated tires in either the 195-65-15 or 215-60-15 tire sizes.
You are much better off looking at a 16" or 17" rim. and your tire selection will be huge. Especially if you go for a 16x7 or 17x7 rim.
17x7 would give you the option of a 225-45-17 one of the most popular tire sizes on the market. You should be able to find a decent rim at the tirerack very cheap without issue.
Well then your likely stuck with an H or V rated 215-60-15 for the best grip, but I wouldn't expect then to handle much more then a stock tire. I mean 60,000mi and performance are some what mutually exclusive.
