92 legend cruise control
Old Mar 3, 2007 | 07:22 AM
jbb123's Avatar
jbb123
Default 92 legend cruise control
my cruise has never worked, at first i thought it to be cause of a bad speed sensor, but after replacing the sensor, still no cruise. light works on button but no response from the others... suggestions??
Old Mar 21, 2007 | 11:20 AM
wfrye924's Avatar
wfrye924
You might try the throttle control module ( connected to the throtlle body cables). You should be able to find one at a reasonable price from a salavage yard.
Old Apr 11, 2007 | 07:13 PM
spotted zebra's Avatar
spotted zebra
Default Cruise Control
Check the brake light switch. The brake light switch on those cars is a double switch. One side works the brake lights, the other side kicks off the cruise control. I had one once that the cruise side of the switch went bad. It was a interesting repair. Also check that the switch is adjusted properly. If it's adjusted to tight the cruise may not work. Try lifting up on the brake pedal with your foot while trying to set it. The cruise control systems are very complicated on these cars. Don't over look the basics. Check the fuses... etc. Let us know how it goes.
