Help w/ seat belt sensors?
Old Feb 27, 2007 | 08:56 AM
Si bLouThru's Avatar
Si bLouThru
Default Help w/ seat belt sensors?
Does anyone know how to turn off the beeping to those annoying seat belt sensors?
Old Feb 27, 2007 | 12:53 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Put your seat-belt on
Old Feb 27, 2007 | 06:17 PM
Si bLouThru
cool.
Old Feb 27, 2007 | 06:20 PM
Si bLouThru
I'll tell my dog to buckle up the next time he is crusin' in the front seat, wise ass.
Old Feb 27, 2007 | 06:39 PM
Fuse's Avatar
Fuse
You are talking about the pass. seat ya thy have seat weight sensers no way around it with out damaging the srs system.Sorry.Your dog could ride in the back????
Old Feb 27, 2007 | 07:14 PM
Si bLouThru
Thanks man, thats exactly what I wanted to know.
Old Feb 28, 2007 | 10:19 AM
boltuprite's Avatar
boltuprite
buckle the belt first, then put your dog in, you may want to disable the air bag though. It tells you how to do that in the owners manual I believe
Old Feb 28, 2007 | 11:39 AM
AppleSauseSi's Avatar
AppleSauseSi
Critical S.O.B.
good luck getting instruction on deactivating safety systems.
here is the real answer to your problem pet seat belt
Old Feb 28, 2007 | 04:56 PM
buckle the belt behind your dog
Old Mar 1, 2007 | 04:49 AM
boltuprite's Avatar
boltuprite
saw this in another Honda forum
"Here you go....Undo the two tiny torx screws that hold the seat belt together. Click the other part of the seat belt in and watch how it works. You'll notice it pushes on a small button. Now, get a piece of sheet metal about 1/2" wide and an inch long and about 40 thousanths thick. Bend a 90 degree leg on it, and put it up to the switch, now bend the other leg so you can slip it over the switch so it keeps the button depressed. Check for interference and trim as necessary. The clip will look like a "U" but the rounded part flat. Now reassemble. The only drawback is the yellow "passenger air off" light will stay on until someone over 45lbs sits in the seat."
