type r internals
Dec 30, 2006 | 07:38 PM
type r internals
can u put compleat type r internals in a b16a and if yes how much would this run
Dec 31, 2006 | 06:23 AM
what internals are you talking about? head - cams, springs, valves, etc. bottom end - pistons, crank, rods, etc.
2005 s2000
Dec 31, 2006 | 07:49 AM
Quote:
Originally Posted by
shivers
complete internals like cams pistons valves rods crank yes every thing in side the motor
Dec 31, 2006 | 09:39 AM
complete valvetrain can be swapped. as are the pistons with slight modification to the rod or piston. that's about all you can use from a type r.
Dec 31, 2006 | 10:29 AM
Snoopy
Yep. You can't use the crank or rods.
Dec 31, 2006 | 05:46 PM
Snoopy
like what kind of slight modafaction 2 the rods or piston
Dec 31, 2006 | 05:47 PM
SHUA619CIVICSI
shaving off 1mm from each side of the small end of the rods, or doing the same to where the rod meets the piston.
Jan 1, 2007 | 07:33 AM
Snoopy
HOW MUCH HP CAN I XSPECT WITH DOING ITR INTERNAL AND IS IT WORTH THE COST
Jan 3, 2007 | 02:04 PM
with itr cams and pistons, along with some tuning, i'd guess 10-20whp gains arent too over the top.
Jan 4, 2007 | 08:58 AM
I picked up ~20whp by using ITR cams, intake valves, valvesprings, and pistons with my original P72 head and intake manifold. Tuned with a VAFC and stock injectors.
