type r internals
Old Dec 30, 2006 | 07:38 PM
SHUA619CIVICSI's Avatar
SHUA619CIVICSI
1991 CIVIC SI
Default type r internals
can u put compleat type r internals in a b16a and if yes how much would this run
Old Dec 31, 2006 | 06:23 AM
shivers's Avatar
shivers
Moderator Alumni
what internals are you talking about? head - cams, springs, valves, etc. bottom end - pistons, crank, rods, etc.
2005 s2000
Old Dec 31, 2006 | 07:49 AM
SHUA619CIVICSI
1991 CIVIC SI
complete internals like cams pistons valves rods crank yes every thing in side the motor
Old Dec 31, 2006 | 09:39 AM
Snoopy's Avatar
Snoopy
been there done that
complete valvetrain can be swapped. as are the pistons with slight modification to the rod or piston. that's about all you can use from a type r.
Old Dec 31, 2006 | 10:29 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yep. You can't use the crank or rods.
Old Dec 31, 2006 | 05:46 PM
SHUA619CIVICSI
1991 CIVIC SI
like what kind of slight modafaction 2 the rods or piston
Old Dec 31, 2006 | 05:47 PM
Snoopy's Avatar
Snoopy
shaving off 1mm from each side of the small end of the rods, or doing the same to where the rod meets the piston.
Old Jan 1, 2007 | 07:33 AM
SHUA619CIVICSI
1991 CIVIC SI
HOW MUCH HP CAN I XSPECT WITH DOING ITR INTERNAL AND IS IT WORTH THE COST
Old Jan 3, 2007 | 02:04 PM
Snoopy's Avatar
Snoopy
with itr cams and pistons, along with some tuning, i'd guess 10-20whp gains arent too over the top.
Old Jan 4, 2007 | 08:58 AM
IN VTEC's Avatar
IN VTEC
I picked up ~20whp by using ITR cams, intake valves, valvesprings, and pistons with my original P72 head and intake manifold. Tuned with a VAFC and stock injectors.
