Valvoline Throttlebody cleaner SUCKS AZZ...need suggestions
ok, note to all who have thought of using Valvoline Throttlebody cleaner...it might as well be pressurized water...doesn't do jack shizznit.
The throttlebody has a light coating of black stuff around its edges. Any idea how to get that stuff off? I don't wanna take the throttlebody off, but I guess I will if I need to. Thanks guys
When I changed my headgasket and had the IM and throttle body off the car, I looked at my t/b, and from the backside, there was some black stuff around the edge of the butterfly plate. I cleaned the t/b with intake cleaner, but the black stuff was on there pretty good. It felt almost rubbery, like high temp silicone or something. I'm not exactly sure, but I think it was applied from the factory to help seal the throttle plate when it's in the closed position.
every honda throttle body i have dealt with had the same stuff on the backside of the butterfly too....thats for 2 h22a's, an f22a1, d15b7, d16z6 and a b18c1...
Yah, its this sealant they put on from the factory, to help maintain a good seal. I find that on all the TBs I have played with, the sealant is all cracked and **** though.
If you ever taken apart the butterfly plate from an H22 or something, each butterfly has the same coating on the edges too.
