gsr tranny
Old Dec 24, 2006 | 03:17 PM
kenny7231's Avatar
kenny7231
Default gsr tranny
Does ne one have an idea how much does it cost to rebuild a gsr tranny!!! my second gear just started grinding at high rpm but does not do it at low rpm. also the 3rd has a little grind ne help would be great thanks
Old Dec 24, 2006 | 03:25 PM
Snoopy's Avatar
Snoopy
been there done that
a lot. basically, i had the same issues and asked a local shop how much it would be to replace the syncro's. they straight out told me it would be better and cheaper for me to just buy another tranny.
Old Dec 24, 2006 | 03:44 PM
kenny7231's Avatar
kenny7231
thanks man!!! Guess i better find a tranny!!!! b16 and typer tranny the only difference is lsd? right?
Old Dec 24, 2006 | 03:49 PM
Snoopy's Avatar
Snoopy
correct. unless you get a 98+ jdm itr tranny which is basically b16 1-3, gsr 4-5, lsd, and a 4.7FD.
Old Dec 24, 2006 | 03:56 PM
kenny7231's Avatar
kenny7231
Thats the best tranny for me right? or should i stick with the gsr tranny? the type r tranny cost about 1200? or more right?
Old Dec 24, 2006 | 04:04 PM
Snoopy's Avatar
Snoopy
b16 and type r tranny's have a higher cruising speed. so at 80mph you're roughly at 4500rpm. if you can live with that definitely go for it.
Old Dec 24, 2006 | 04:08 PM
kenny7231's Avatar
kenny7231
iirc i think at 80 im at 4k so i guess my 500 more rpm wont make a difference!!! ne ideas where to get a good tranny?
Old Dec 24, 2006 | 04:11 PM
kenny7231's Avatar
kenny7231
hey can u tell me whats the difference between the 97 and 98 jdm type r tranny? is it the final drive. 4.4 vs 4.7?
Old Dec 24, 2006 | 04:13 PM
Snoopy's Avatar
Snoopy
check the classifieds on here and h-t
the FD, and different 4-5 gears. all usdm itr trannies are the same.
Old Dec 24, 2006 | 04:34 PM
hitman619's Avatar
hitman619
SDSU Basketball
here in So.Cal a used gsr transmission runs about the same as Rebuilding one
check around your local transmission shops for prices
be careful of the old "bait and switch"
junk yard wanted 750.00 inculding labor 6 month warranty
Transmisson place wanted 875.00 and included a type R limted slip
plus a 12 month warranty
