LS/GSR trans question
Old Dec 23, 2006 | 02:58 AM
hybrid_SI's Avatar
hybrid_SI
Default LS/GSR trans question
I have a 95 integra LS special edition which was bought used and I'm starting to have starter problems. I know for sure it's the starter that's going bad. But my question is....is the starters from a LS and GSR interchangable? Reason I'm asking is because there has been 2 incidents where I bought the correct starters (NON vtec DOHC) and both times the top bolt does not line up on the trans. Could the GSR starter fit? There is a sticker code on the trans and the first 3 letter/numbers is Y80 if this helps. Any help would be greatly appreciated. Thanks!
Old Dec 26, 2006 | 03:29 PM
Nors's Avatar
Nors
倍力恋
Y80 is a GSR trans.
Edit: wait.., give me a sec.
Okay, seems that GSRs and LS/RS's use the code Y80. Seems to be a big mystery I guess.
Old Dec 26, 2006 | 11:48 PM
jesusublime99's Avatar
jesusublime99
They are interchangeable, they are the same part from Acura(94-95 MT only).
31200-P72-A02RM
Old Dec 27, 2006 | 10:46 AM
Spec R's Avatar
Spec R
I had a 95 GSR y80 in my 00 LS. The starter that came with car worked just fine.
DB Squad
Integra Forum Moderator
