A cuple questions about rebuilding...
My 92' LS for turbo. Now I have already bought a set of SRP pistons, and rods. As for tuning I went with a SAFC by Apexi and upgraded injectors to 350cc. I only want to run about 7-10psi with a t3/t4 setup. The reason I am diong this is because i recently blew a whole threw my last block, while rrunning to lean with a DSM turbo setup. I have a spare b18a1 sitting in the garage but I am not quite sure i can get away with just using that one and putting everything back together. What needs to be done..?
p.s.-there is small surface rust in the cylinders that needs to be hoaned out.
bore and hone each piston to each cylinder. replace all the bearings, seals, gaskets, pumps, and belts. you need something better than a crappy safc for tuning. like mentioned above a chipped ecu and hondata or similar is ideal. psi is irrelevant. shoot for a hp goal. built and tuned correctly you could safely do 300-350whp.
hey thanks for the response, but I am really just looking for what I have to do to the block 1st to make it pretty dependable while running boost, but nothing to crazy. My pockets arent deep enough yet, so i am just taking step by step. But thanks for the input.
p.s.-Not looking for great HP numbers right off-the-bat people. thanks.
