need to remove the right side door and starting problems in the summer
I live in japan and have a 93 vtec prelude si I want to remove my old door and get one from a junk yard and swap it but I dont have a clue what to do
THat and have you ever had a problem like its flooding It will start fine but if I shut it off run into a store and run back sometimes it wont start the first time and then i have to wait 15 min or more and then it will start fine. IN the summer if it is real hot it also wont start the first time I have to wait for 30 min or more and then sometimes it will start
Your Main Relay's going bad...just do a search for it...very common, especially on hot days.
As far as the door, get a floor jack, put a piece of wood on it, jack up the door a little bit, undo the 4 bolts, unhook wiring hardness
Opposite for install.
