civic front speaker wiring
Old Dec 3, 2006 | 03:58 PM
semarlor's Avatar
semarlor
03 Accord 6MT
Default civic front speaker wiring
hey guys, i'm new to the site...but i def like what i have read so far.
the problem is with the speaker in the driver side door. it seems to me like there is a bad connection somewhere, because every now and then the speaker will make a buzzing noise and sound like crap. the speaker can't be blown because it doesn't always make the sound. and something weird that i noticed the other day, when i push the brake pedal down, the buzzing in the speaker gets louder. anyway, my question is...does it seem like just a bad connection to the speaker from the head unit (or the other way around) or do i need to run a new speaker wire completely? i'd appreciate the help before i do any work that doesn't need to be done
Old Dec 3, 2006 | 05:35 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Check your wires behind the radio first. Specifically the ground connection.
Old Dec 3, 2006 | 06:19 PM
semarlor's Avatar
semarlor
03 Accord 6MT
i was hoping someone would say that. i have always used splice connectors (the ones that you crimp on both sides, i am sure there are different names for them.) is that the best way to go? or would something else give me a more reliable connection
Old Dec 3, 2006 | 06:24 PM
totalimmortal
MalleusMaleficarum
I've always used wire caps, not to be confused with wire nuts.
Old Jan 1, 2007 | 06:11 PM
mjlenz's Avatar
mjlenz
What did you find wrong with your speaker problem?
Old Jan 1, 2007 | 09:59 PM
b00gers's Avatar
b00gers
It really sounds like a wiring issue.
The best way to connect wires together is to solder them together...then put a covering like heat shrink over the solder. And a ground connection to the chassis is best when its firmly attached to the bare metal (no painted surface).
