Question about Performance with car.
Hey guys I want to do a FEW things to my car So far Nice rims, Sport Guadges, (Soon) and (Now so far) got Some nice headlights also Clear turn signal lights. (goes good with my silver car.) Performance, a nice Exhaust system, Cold air intake, Mabye headers? Then thats it.
Questions what are good brands of Exhaust systems that will pass Cali smogs (Hp gain about 3-6?) Cold air intake (3-6)? Would headers be overkill?
Next thing i am going are looking for next are Some nice performance spark plugs (Heard NGK good, What is difference between Iridium Vs. Platinum?
I want some good performing spark plugs and wires?
Heard Bosch Sucks, any other spark wires or Spark plugs you guys suggest
So with all these mods about 15-25 HP Gain and little better acceleration?
Will someone PLEASE Explain Cold air intakes to me? I am so confused so you loose power in some areas, but gain in others if so what is the point?
if you want to pass cali smog stick with an aem intake, dc 4-1 header, and exhaust of your choice. something quiet is the rsr exmag or apexi ws.
stick with oem everything for the ignition. no gains whatsoever from upgrading the ignition.
you're lucky to see 5-10whp from i/h/e
the power gains/losses in the powerband from a cai are nothing to fuss over. it's not a whole lot anyway.
preference...i like NGK IX iridium tip spark plugs personally...though most spark/ignition upgrades are minimal on most cars they can help to prevent future problems..you have boost and detonate...you'll wish you upgraded the ignition/spark system
I prefer NGK copper plugs. Iridium plugs have been known to have the little super-hard tip of iridium melt off into the combustion chamber and cause some real problems. Copper plugs will yield the best spark but they have a short lifetime.
To me, it is a moot point because I have seen a couple 700+ whp dyno graphs/setups on honda-tech running stock ignition with absolutely no problems or hiccups in the powerband. I am not saying it would be reliable at all since it would burn through rotors and coils like crazy...with that kind of power, one should run coil packs.
Here is an example of 728whp, stock ignition.
Ignition upgrades are completely unnecessary. There are plenty of guys running 500+ whp on stock ignition. If you have a problem with detonation, look at the tuner, not the ignition system. MSD stuff is junk and the source of many ignition problems for these high-hp guys.
then replace it with new oem wires and plugs. you'll be spending $200+ dollars on those wires and plugs that dont perform any better than oem.
