How would I replace Regulator
Old Sep 22, 2006 | 03:57 PM
Dnguyen242's Avatar
Dnguyen242
Noob
Default How would I replace Regulator
I got my dad old 92 honda accord and the Right rear window is not work right. I know I have to replace the Regulator but I dont know how to take that panel off. I hope some one can give me a detail on how to take that panel off.
Thank you
Old Sep 22, 2006 | 05:15 PM
simplyredvw's Avatar
simplyredvw
That's odd for a rear window regulator to go out. You have checked the switches, right.
Old Sep 22, 2006 | 06:24 PM
4cylinder4ever's Avatar
4cylinder4ever
have you checked fuses? relays? maybe the motor too?
Is it not working at all, or is it just not moving up and down, but you hear the motor trying to move it? if so, the regulator IS out, if the motor doesn't make a sound, then check the fuse relay and eventually the window lift motor itself.
hope this helps
Old Sep 25, 2006 | 12:07 AM
Dnguyen242's Avatar
Dnguyen242
Noob
Default Yes
Yes I check the every thing. and it seem just that one to go out. all the fuse is ok. I know it not the switches because the front left controler switches cant be all out too if it work with the other windows. and I check the fuse box they all seem to be ok. I know it the regulator or the motor no sound. So I want to open the panel but dont know how it would open with out breaking some thing. If some can take or draw some pic and e-mail me the information on how to open it so I can check the regulator and motor that would help a lot. thanks.
Old Sep 25, 2006 | 07:41 AM
wedley2's Avatar
wedley2
bboy Wesley West
there are three phillips screws, one in the door handle, one behind the handle and one inside the larger handle (the "oh shit" handle)
with those off, id suggest pulling from the bottom and the panels should come off.
if i remember right, there are a combination of 10mm nuts and bolts to get the regulator and window off. mine went out too
Old Sep 25, 2006 | 09:41 AM
Dnguyen242's Avatar
Dnguyen242
Noob
so there only 3 cool and thank. how much did you pay for your Regulator andd motor. just asking. ok going to remove that panel to day. Hope I dont break any thing.
Old Sep 25, 2006 | 11:10 AM
Dnguyen242's Avatar
Dnguyen242
Noob
wow thank Wedley2 that help a lot I just remove the Regulator and it wasnt broken. Just a bit if the plastic was broken off and stuck in the wired so it could move. but that was hell taking off the door to get to the windshild. But I got it done. Sove me $$$ since I didnt have to replace the Regulator and did it my self.
