Shaved door handle/alarm?
Hey guys i just got a 7 channel shaved door handle kit from autoloc, and i was thinking about buying an alarm as well. My question is how would i get the shaved door handle kit and the alarm to work togather?
take it to a shop that installs alarms, and it shouldnt be a problem. i'm not a big fan of those shaved handle systems. you should put a spare battery in... if your battery dies, there is no getting into your car.
more than likely your status output from your alarm to the input to the autoloc brain also you can use a relay and have it pop when you press your unlock button on the fob. just matters what the installer knows
personally i wouldnt do shaved doors, just like shallow bay said your battery is dead u are fawkd, that or if they come loose u need an lever to open the door from the inside, my boy did it in his car
