b18c1 w/ctr internals what do you think?
Old Aug 25, 2006 | 09:44 PM
jrw1818's Avatar
jrw1818
Default b18c1 w/ctr internals what do you think?
someone told me to go with ctr cams an ctr heads. an ctr cam gears.. then a skunk2 intake manifold. is that the best thing to do to make it fast? true??
Old Aug 26, 2006 | 12:53 PM
Snoopy's Avatar
Snoopy
been there done that
yes!!
stop listening to what other people say, who obviously dont know what they're talking about, and do your own research so YOU know the facts.
Old Aug 26, 2006 | 01:45 PM
jrw1818's Avatar
jrw1818
cause someone told me it's too hard on the bock if i went with skunk2 cams.. an if i did it that way i would be pushin 175whp.. true?? what do you think is the best way to go as if it where your b18c1??
an how do you fix the header on this thread?? i spelled it str an not ctr..lol..
Old Aug 26, 2006 | 01:52 PM
Snoopy's Avatar
Snoopy
i do have a b18c1. and if i had the money to build my head i would do:
-rlz ported head
-rocket m22xx cams and valvetrain
-stock itr valves
i didnt come to this conclusion overnight. i spent lots of hours on HAN and HT reading and researching. i suggest you do the same.
Old Aug 26, 2006 | 09:06 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Correct me if I am wrong but isn't the CTR built for more endurance than flat out speed?
Old Aug 27, 2006 | 09:03 AM
2001TEGGSR's Avatar
2001TEGGSR
How "fast" do you want to go??
Whats your end HP goal?
Whats your Budget?
Who's performing the work?
Do you have another mode of transportation for the downtime of your teg?
Take all this into consideration before making a decision on what to do. By the time you buy all that stuff, you can make alot more power in other areas on the same amount of cash.
Old Aug 27, 2006 | 09:59 AM
jrw1818's Avatar
jrw1818
well i would be doin it slowly so i can drive it.. i know when i put some of the part's i wont be drivin it for atleast 2 day's.. my goal is for it to be hella fast.. i'm not gonna bore it or anything like that.. i'm tryin to get lots of torque...
Old Aug 27, 2006 | 10:01 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you want "hella fast" and torque, you won't get it N/A.
Old Aug 27, 2006 | 10:09 AM
2001TEGGSR's Avatar
2001TEGGSR
:werd:
And to gain the power your speaking of, id still recomend getting a second block to build as you have the money. Then you dont experience as much downtime. You build on the block until you have everything, get a F.I. setup, then you take a week or two & swap it in. After that you can sell your stock block. Just my 2 cents...
Old Aug 27, 2006 | 01:05 PM
Snoopy's Avatar
Snoopy
well you wont get lots of torque unless you bore it out or stroke it. or boost it.
