Alarm remote battery, where to buy.
Old May 1, 2006 | 08:30 AM
Tankard's Avatar
Tankard
Default Alarm remote battery, where to buy.
Where can you buy the little battery in the alarm transmitter. Can you get one at Walgreens or CVS pharmacy, or would you have to go to your local car stereo/alarm place?
Old May 2, 2006 | 06:03 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Just about anywhere that has batteries will have them. Most of them are either a CR-2025 or a CR-2032.
Old May 2, 2006 | 09:23 AM
Tankard's Avatar
Tankard
Alright. Thanks Mr. Beanona Lisa. Heh. It's not my battery though. I got my other transmitter that i've never used, and it works just like the one i'm using now. You have to press the button more than once sometimes very close to the car for it to arm/disarm. Maybe the antena at the moduole came partially undone or something. When the battery dies, does it usually die all at once or what. I noticed it was 12 volts and my tester only does1.5 and 9 volt batteries. The needle jumped to the top when i had it on 9 volts, so i don't think it's the battery.
Old May 2, 2006 | 09:24 AM
90CvcDX's Avatar
90CvcDX
kekeke
radioshack has them, usually a 2 pack so you can replace both batteries
Old May 2, 2006 | 09:27 AM
Tankard's Avatar
Tankard
Alright. Thanks. That's where i'll go when i need one. It's the closest place to my house.
Old May 2, 2006 | 10:30 AM
i gotta replace mine soon, sucks getting locked out of your car
Old May 2, 2006 | 01:21 PM
totalimmortal
MalleusMaleficarum
Where is the antenna placed for the alarm?
Old May 3, 2006 | 10:09 AM
Tankard's Avatar
Tankard
I have no clue. When i purchased the alarm, many years ago, it was installed free with the purchase of it. Why do you ask?
Old May 3, 2006 | 07:14 PM
totalimmortal
MalleusMaleficarum
Because, antenna placement as well as routing of the wire can have an affect of it's peformance. "Supposedly" your not supposed to bundle up extra antenna wire because it cuts down on range, don't know how true this is.
Old May 4, 2006 | 08:55 AM
Tankard's Avatar
Tankard
I went and pressed the wiring harness into the main brain of the alarm. It now works perfect again. It must have been loose or something.
