View Poll Results: which?
80.00%
2
3
20.00%
Voters: 15. You may not vote on this poll
Which 240SX is better?
1. This one is 15-20 minutes from me.
http://www.imagestation.com/album/pi...?id=4285886525
1990 240SX hatch.
156k miles
remote starter
new front pads and rotors, belts, valve cover gasket, complete tuneup,
has an exhaust leak
small dent
automatic
but the seller has a 5 sp tranny and a new exedy clutch kit he is willing to sell with the car. Car + tranny + clutch kit for $1200
I've read up on transmission swaps and there is no way I can do this without professional help. How much does the labor cost for something like this?
Also, I'm definitly going to swap out the pig-nose front if I purchase this one.
2. This one is a bit farther away. 40min to an hour I think.
This guy made a huge fucking post so i'll just post it here.
has a bunch of minor problems with it, but at least I won't have to do a tranny and front-end swap :dunno:
1990 240SX hatch.
156k miles
remote starter
has an exhaust leak
small dent
automatic
Originally Posted by njandrewg
First the details, I'm disclosing everything I know about this car, so there should be no surprises.
Year: 1993
Mileage: 186xxx
Transmission: 5 speed
Trim: Hatchback STD model(lightest) Aztec Red
Asking Price: $1500 firm, reasons: a) its a KA24DE b) its already manual c) $500 worth of repairs were already done, yes I know you don't get paid for that but still. d) good tires, except for that bad one. e) with fast and furious 3 around the corner it'll be worth like 2500 :P
Car is located in zip code 07078
to contact me: email me at njandrewg@yahoo.com
Whats wrong with it
-Wheel studs are stripped. And pretty bad, they go in very rough. Very cheap fix though. And if you want I can sell you ARP Extended Wheel studs for $40(they cost $80)
-seats have wear spots, I can throw in some black/gray seat covers, and another set of blue seats, or you can buy some aftermarket seats from me.
-Washer nozzles don't work, from the looks of it the pump for that is broken
-tint is purple
-1 tire is leaking air majorly
-1 of the red rear side markers is cracked(I have a replacment, which will come with the car), beides that all glass is good.
-1 of the shock towers is polished, when i was trying to remove the rust, there is still some there but very minor. I spray painted over it with clear coat so it shouldn't rust any more.
-there is a minor dent on the rear 1/4 panel.
-sometimes its hard getting it into reverse, have to force it in.
-has some scratches here and there.
-battery died on me over the winter, so it'll need a jump to get going.
-brakes seem rusted...for the same reason also
-front bumper has some paint pissing.
-antenna isn't hooked up(my first stereo install and I forgot to put it in.
-there might be an exhaust leak, since the car is pretty loud.
-probably needs an oil change
-ebrake goes up a lil bit too fast, not too certain if it works.
-one of the bolts holes holding the passenger seat rusted off cleanly.
-car is not registered currently.
Overall nothing major for a 13 year old car.
The good.
-Runs strong, and is a KA24DE
-its a 5 speed
-good tires, the one that leaks air should be patched up and should be good as new. Tires still have the little nipples on them.
-Interior was fixed, new shift boot, new shift knob, new floor mats, cd player, din pocket. When i got it, all that was gutted.
-Exterior was somewhat fixed too.
-I will also include a set of OEM headlight motors, and oem headlights.
-its already wired for a sub
-doesn't seem to be leaking oil
-clear car fax
-inspection good till 2006, I think june
-clutch seems to be working fine
-timing chain was changed 2 years prior to my purchase of it, so i'd say about 30K miles ago
Anyways the story: I bought the car last may, and its been sitting in my garage since then, I fixed the interior, fixed the exterior somewhat, and did the lighting. Pretty much in that whole time, the car was driven 30 miles from the guy's house to mine. It drove fine, except the handling sucked cuz the tires were bald as hell. Then I put my car for sale hoping for a quick one so I could drive the 240, but lets just say there was absolutely no interest so I finally decided to keep it, and sell the 240.
List of all parts purchased to fix it;
$15.00 Black Shift boot w/ red stitching 5/12/2005
$18.95 Type R style knob 5/12/2005
$40.00 New Floormats 5/16/2005
$40.00 Blue Seats 5/20/2005
$20.00 Din pocket 6/2/2005
$50.00 ESA CD Player 6/4/2005
$3.41 Owner's Manual 6/6/2005
$49.99 Black /Gray Seat covers(Say CLA racing) 6/7/2005
$18.00 Turn Signals & Headlight Covers 6/8/2005
$24.00 Side Markers 6/9/2005
$50.00 OEM Hood 6/15/2005
$23.95 H4 Luminics Bulbs 6/24/2005
$34.95 H4 Projector Headlights 6/28/2005(top of the line, glass, not plastic)
$15.00 Those black plastic headlight holders.
$100.00 15" Steelies with "new" futura tires 7/5/2005 -1 ended up leaking air
Total: 503.25. So close to $500 getting the car in shape some what.
What it needs to be in best shape:
Wheel Studs $40 if you want the ARPs.
Washer bottle with pump, which i've seen on ebay go for $12+ $5 shipping
1 new tire, like 50 bucks at pepboys, or you can just haev this one patched.
Maybe new battery cuz this one has some white crap around it $50. Oil change. Some bondo for the rear dent.
Moving on some photos
Here you can see it on steelies
Here you can see the dent, its pretty minor
Clutch pedal old owner had
Some more interior
Seat covers
H4 Conversion
light output
The polish in the engine bay, as you can see it could use a lil bit more polishing.
The different seats
Engine bay
Overall I think this is a good deal for what you get. And with a little bit of maintance it can be top notch.
And some other parts you can buy from me:
ARP Extended Wheel Studs $40
Whiteline Front Sway Bar $100 (adjustable, not sure but I think comes wtih endlinks also)
Apex Rear Strut Bar(ebay specail) $30
Racing Gear JTC'N1 coilovers $1500($2500 new) (8/6, non adjustable, and pleeeease do not compare them to Teins)
Megan Front Strut Bar $40
APC Super Sport seats $360
C pillar bar $35
Skyline R32 GTR JDM Wing= $100
Momo Air Race blue/black leather shift knob-$30
Year: 1993
Mileage: 186xxx
Whats wrong with it
-tint is purple
The good.
-its a 5 speed
-clear car fax
Some more interior
Seat covers
H4 Conversion
light output
The different seats
Engine bay
C pillar bar $35
First one, just leave it auto.
2nd one is a pile of shit.
The only reason why I even considered the second one over the first one is because of the tranny and the front end. :hs:
If you really want to pay for the manual swap, good luck...but you'll need more than just the tranny and clutch.
honestly, either of those 2 are going to need lots of work regardless of pricing and what comes with them.
i say pick the one that requires less work to be in tip-top shape.
DB Squad
Integra Forum Moderator
DB Squad
